You probably get this all the time but I still need to know…
Rabidreject
Post by Rabidreject »
I have a drum 4 as well as an edrumin 10. I’m about to start getting back on trigger building and I’m wondering if it will support the pads that utilise 3 (or more) piezo’s all round the edge of the drum….
Does positional sensing work with those style triggers or shall I just go with the normal dual zone….
Thanks
Re: You probably get this all the time but I still need to know…
There is support for pads that use 3 side mounted sensors, however it's a bit experimental, more complex to dial in, and isn't as granular (you will likely only be able to reliably get center and off-center zones).
