Millenium ride cymbal
Krlu
Post by Krlu »
Did anyone successfully set up a 18 inch millenium ride with regards to bell sensing? I have not yet been able to assign this. I see it is not on the officially supported list. Will there be plans to integrate this in future? Kind regards fresh edrumin 8 user
Re: Millenium ride cymbal
That cymbal only has one jack, so perhaps it's using the same wiring as Yamaha cymbals. Have you tried setting it as a Yamaha 3-Zone ride?
Krlu
Post by Krlu »
Perfect; this is the solution (with the bell/edge swap). I somehow missed this. Thanks, and also thanks for supporting and creating a great product
