Owners manual says Roland RT30-HR trigger supported but it's not in the presets?
StarFishPrime
Post by StarFishPrime »
Basically what the Subject line says.
At a higher altitude with flag unfurled
We reached the dizzy heights of that dreamed of world - PF
Re: Owners manual says Roland RT30-HR trigger supported but it's not in the presets?
Of course there's no preset. Each drum you use that trigger is going to need personalized settings.
StarFishPrime
Okaaaayyy.... Just plugged this thing in for the first time and am going through the manual and watching a few videos. In the "Trigger Presets" there's a bunch already there. 40 of them. Do these also need personalized settings? In the manual under supported pads it listed my Roland RT-30H so I thought I would find it in the presets.
That section in the manual simply states the pads / cymbals/ triggers that I used when developing eDRUMin. The included presets are for commercially available pads / cymbals--most of which I own. Most should work well, but could always use slight adjustments to match individual playing sryles.
