Latest build 2.1.1 build 5 - issue?
Edrumin4 - Latest build 2.1.1 build 5
Rack Toms, Floor Toms, and Kick (Double bass drums) are split.
No issues with Rack Toms and Kicks.
Floor Toms are split, mesh 3 side sensors selected.
1. Floor tom not being sensed. I can switch cables between the 2 floor toms , and either floor tom1 is sensed and Floor Tom 2 is not being sensed, or vice versa.
Does it matter which gets the Tip or Ring. Tried either way.
2. Why are the icons for mesh 3 side sensors showing Bow?
thankx
ron
Re: Latest build 2.1.1 build 5 - issue?
I'll look into this today. Thanks.
I did a very quick test. I put an input into dual mono and set both pad types to 'Mesh 3 Side Sensors' and they both worked just fine. I suspect you splitter is stereo -> dual stereo. You need a stereo -> dual mono.
As for the articulation showing 'BOW', I can confirm that that is a bug and I'll fix it for the next build.
