Daisy Chaining a td-17
Andrewmsb
Post by Andrewmsb »
Hi all. So I purchased a Edrumin 10 I could not get it to work with my ALESIS horrible nitro the way I wanted to. So I sold it and purchased a Edrumin 4 to use with my td-17. So is there a guide on how to daisy chain the td-17 and the Edrumin 4 together. I just unboxed my unit. I'd like to make sure I am setting this up correctly. Do I download the software first and set it up then daisy chain. I am just unsure of the steps and how to get these recognized in SD3. Is there a guide? All I am trying to do is add a 15 inch ALESIS crash ride with a stereo cable as a 3 zone ride in the Edrumin 4 so it can be recognized with the td-17 in superior drummer 3. Thank you.
Re: Daisy Chaining a td-17
Just connect both the eDRUMin and the TD-17 to your computer and select both devices in SD3.
Andrewmsb
Post by Andrewmsb »
Rob, do I do it by plugging the td-17 into the Edrumin somehow or as separate entities, if so. I am out of USB inputs.
