Change Midi channel?
ddropski
Post by ddropski »
Hi everyone I have a question and I know there are alot of smart people here that can help ..
here is my problem i have 2 kat drum pads they hard code the Midi channel to 10 and you can't change it ,, if I run superior drummer as a standalone they both work fine but when I load pro tools only 1 can be seen and works (probably because they are both using midi channel 10) so My question is there a way I can change the outgoing midi channel to something else using a piece of free or paid software?
I am using a P.C. and the pads are connected USB? Thanks, everyone
Tkydon
Re: Change Midi channel?
Post by Tkydon »
There is a MIDI software called MIDI-OX that might be able to change the channel for you.
If you can't change the MIDI Channel, can you change the MIDI Note?
There shouldn't be any problem having multiple MIDI devices using the same MIDI channel. I think your issue is elsewhere.
