Roland Digital Snare and Ride Cymbal
mickey
Post by mickey »
Hi, Can someone tell me how to connect my Roland digital snare drum and ride when using the edrumin module?
Im currently using a TD50x but bi-passing ALL the sounds by using Superior drummer 3
I would like to purchase an edrumin module if I can utilise my Digital pads.
Thanks
Re: Roland Digital Snare and Ride Cymbal
You could either plug them directly into your computer, or into a USB hub connected to the USB host port of an ED10. Keep in mind that you would not have positional sensing from your snare and ride if you aren't running though a Roland module.
Thanks
