When using third party triggers for the snare drum, is the Hotspot Suppression better with a cone trigger instead of a cylinder trigger?
Also, is the Hotspot Suppression better in the eDRUMIN 10 than the four input model?
Hotspot Suppression Questions
Re: Hotspot Suppression Questions
It was designed around pads that use cones, not cylinders.
There should be no significant difference in HSS performance between ED4 and ED10.
