eDRUMin 10 with VH10 and EZ2
stipsi
Post by stipsi »
Hello
I am currently playing on my DIY drum with a Roland TD9 and EZ2. So far so good except for my Hi-Hat Roland VH10. The hi-hat does not work badly with my TD9, but unfortunately not to my satisfaction with the EZ2. The well-known thing with open close ... Now I'm thinking about swapping my TD9 for an eDRUMin 10 because it sounds very interesting and offers a lot of setting options.
Can someone tell me whether my Roland VH-10 Hi-Hat works as well with EZ2 as it does with SD3?
Thanks in advance!
LG
Christian
Re: eDRUMin 10 with VH10 and EZ2
I wouldn't be surprised if the general handling of hihats between EZD and SD3 is identical, but the number of articulations, and hense the amount of detail, is almost certainly higher in SD3.
stipsi
Post by stipsi »
OK, ich verstehe....
Ich würde es gerne versuchen, bis wann denkst du wird eDRUMin 10 wieder Lieferbar sein?
Danke
stipsi
Post by stipsi »
Ich habe mich in die Liste eingetragen, danke!
