eDrumin Control not launching
toma
Post by toma »
Hello, I just updated my control app from 1.5 to the latest 1.6 beta. I'm running Windows 10. I uninstalled the old version, when I try to start it up I see it in the taskbar but it's just a blank window. This is the first time I've had trouble running the app. Any ideas on what I can try? (I have rebooted).
[Please disregard, I have fixed on my own by deleting the folder in appData. Couldn't see how to delete post.]
Re: eDrumin Control not launching
Deleting the configuration problem will resolve your issue. On my system, it's located at:
C:\Users\robert\AppData\Roaming\AudioFront\eDrumIn.cfg
I'm pretty sure this issue happens if the Control Application is closed when it is being shown on a secondary display and then is later reopened when the secondary display is no longer connected. It will be fixed in version 1.6.1. Thanks.
