Few questions please help
ddropski
Post by ddropski »
Hi Forum,
I received my ED10's but I have a few questions
@Rob on our video when you are configuring Dual-zone drum you hit it in the middle head and it consistently jumps to the left yours is very stable and then you hit the rim the line jumps to the right Mine is all over the place middle 1 hits middle same hit it jumps to the mid-right then back to the left etc... can I fix this to be more stable?
also in the same configure section I noticed you have 6 boxes I only have left- brown (or yellow) right Green and the lower part if i drag that up ..
then once I have that sort of working but since it jumps I get mis-triggers here and there
then when I try to do the PS when you hit your drum in the video the line jumps to the right and moves left as you hit to the center ..but mine starts in the center and moves to the right as I hit towards the rim.
I followed your advice and put the rim sensor on the underside of the drum (directly under the head sensor) center-mounted.
can someone please help
Re: Few questions please help
Getting positional sensing to work well comes down to good drum construction.
Attach some pictures so we can see how your build is looking.
Also, you should probably read this thread too because it also applies to positional sensing.
viewtopic.php?f=34&t=951
