Melodics and SP3
dnoob83
Melodics and SP3
Post by dnoob83 »
Hello, I am Pierre and the proud new owner of an eDRUMin10.
With setting and DIY triggers everything went very well, but I have one problem. I want to use Superion Drummer3 and Melodics at the same time so that I don't have to use the annoying sounds of Melodics. But I can use SP3 or Melodics at the same time, as it was with the TD17. Is there a solution for this?
Re: Melodics and SP3
If you have another MIDI DIN input (on an audio interface perhaps), you can with the MIDI Out from the eDRUMin into the audio interface and then on to Melodics and the use the USB MIDI for SD3.
dnoob83
Post by dnoob83 »
Thank you, Rob. it´s work fine.
