hey,
so I just got a new Roland VH-10 and in the eDRUMin application everything works fine
but on SSD5 the controller doesn't get recognized when hitting the hihat.
It doesnt matter if the pedal is pressed or not it always displays it as open if I hit it.
Hi-hat pedal has the right midi note in SSD (G#1) so I'm wondering if anyone has a solution
Hihat Controller vh-10 SSD5
- pedal2.PNG (223.85 KiB) Viewed 660 times
Re: Hihat Controller vh-10 SSD5
Okay I got it fixed, had to midi note that controlable hihat
Hi, could you explain how you fixed it? I have the same problem.
