TheJay wrote:I have five splitters connected to my eDRUMin modules.
Each of the four from Jobeky trigger the first input only regardless of the pad hit, whilst set up in mono mode.
I have one other not supplied by them that works perfectly when configured in the same way.
Has anyone else had this problem?
Was this with metal cymbal pads?
I need to report a bug with this, dual mono rubber pads, no problem, changing to metal type (using same pads, same splitter, same input) the right side triggers the left for some reason
I see an issue there. I'll fix it for version 1.3.2.
Thanks Rob
TheJay wrote:Talking of metal cymbals, are the options added intended for use with a hi hat with bow, bell and edge?
What’s the ‘correct’ process for setting up a bell on a hihat? Separate piezo/dual input like a ride or using bell sense?
