Two zone snare piezo rim
Re: Two zone snare piezo rim
Monitoring through external audio device and loudspeaker. It's not a problem with note assignment in eDRUMin drum map.
Can you please check if the issue goes away if monitoring with headphones?
I reset all the modules and there snare and rim are working. Hi hat is killing me though. Everything is an open hi hat sound. How do I reset any changes in SD3 back to original settings for the add-ons?
I've installed the latest software controller but now firmware has been reset, I can't upgrade. I'm using a PCIe USB controller that worked fine first time.
Check your 'link' between pedal and pad in eDRUMin.TheJay wrote:I reset all the modules and there snare and rim are working. Hi hat is killing me though. Everything is an open hi hat sound. How do I reset any changes in SD3 back to original settings for the add-ons?
I connected to a different port and updated the firmware on all of them. I've got the bass drum connected to the same module as the hi hat. I have noticed there are three drums showing on eDRUMin, even though the other three ports are used by the goedrum plunger and bell and bow piezos? I've got the one that lights up when I hit it as Yamaha 3-zone Cymbal. The other two are set as centre piezo.
Hi hat still driving me mad, triggering for no reason as was right tom rim before and after recording.
https://youtu.be/old00BzTu_8
https://youtu.be/AOP7NoxMkow
I discovered that the two modules connected to TD8 pads were causing that problem.
In the new release I see "link" in pedal settings but don't understand how to link it. Pressing the button seems to do nothing.MWJT42 wrote:Check your 'link' between pedal and pad in eDRUMin.TheJay wrote:I reset all the modules and there snare and rim are working. Hi hat is killing me though. Everything is an open hi hat sound. How do I reset any changes in SD3 back to original settings for the add-ons?
