Not sending midi data through USB?
Re: Not sending midi data through USB?
I've doubled the max USB Host port descriptor size. There's a small chance it'll fix your problem with the Alesis module.
viewtopic.php?f=29&t=1107&p=7777#p7777
negativei
Post by negativei »
Hey Rob,
Just popped in this thread after searching for usb midi send check. The flashing lights on the Edrummin units is the most consistent way to check that triggers/pads are sending a signal to the units? I’ve hit a wall where I’m not getting signal showing in my module but I’m def getting signal indicator flashes on all of my Edrummin units which is a good sign!
In the event that usb is just too janky, a midi merge box to get all 3 of Edrummins into a single 5 pin midi in for the module sounds like it should work. At least on paper.
