Preset: Roland PD-120
Forum rules
Preset for the Roland PD-120 (12" mesh dual trigger, used as snare)
Roland_PD120.edp.zip
(345 Bytes) Downloaded 395 times
CodaClef
Re: Preset: Roland PD-120
Post by CodaClef »
Wait, so how do I load this just onto the snare?
