Tips for calibrating Diamond Drum triggers and Low-Volume Metal Cymbals
Forum rules
Tim
Post by Tim »
I’m having issues getting my Diamond Drum center mount triggers and low volume triggered metal cymbals to work properly.
Anyone have any tips?
They’re all piezo triggers, I believe.
This is my first electronic drum module, so I’m learning as I go.
I appreciate the help!
Here’s a link to the website:
https://diamondelectronicdrums.com/
Retro Rambler
Re: Tips for calibrating Diamond Drum triggers and Low-Volume Metal Cymbals
Post by Retro Rambler »
Hi Tim,
Been out of the loop for a while, long story but the apartment I was living ended up becoming very, very hostile immediately below. Happy to say I don't live there anymore and quite hopefully, will not have any more problems with crazy neighbors on the other side of a wall and playing my edrums into the foreseeable future.
I have one of those brands of kits, minus the bass trigger setup. What type/revision of eDrumin device are you using? I have 4 spring 2020-vintage eDrumin4's. Didn't have too much trouble getting those to auto-calibrate except the bass drum.
I gave up on the bass triggering problems and... well nevermind but I put a UFO Drums bass trigger setup on it and it worked like a champ.
Depending what you're up against I may be able to help. Still setting my stuff up from the move and am also in process of some kit expansion but will try to help if I can re: the drums. Not sure about the Low-volume cymbals though. I am using all ATV's.
