3 trigger snare?
wwwayward
3 trigger snare?
Post by wwwayward »
Hello All
New to eDRUMin community. I was wondering if anyone has a wiring diagram for a 3 zone snare drum? ( center, outer and rim) Has anyone attempted this, how did it work out?
tia
Steff
Re: 3 trigger snare?
Nothing overly special about that setup.
Centre piezo, this alone gives you centre, outer and edge head sounds - eDRUMin (and others) analyse the waveform and determine where you've hit it - essentially magic. eDRUMin is also somehow capable of giving you an edge trigger using the same piezo using 'edge sense'.
An additional shell mounted piezo will also give you rimshot (when centre piezo is also triggered) and side stick.
5 articulations, 2 piezos.
Just needs a stereo (3 pin) jack. Centre L, Shell R, both share ground.
Wiring diagrams in the back of the manual
nemo
Post by nemo »
Hi, this may also inspire you viewtopic.php?p=13681#p13681
GC
