Guitar piezo as drum trigger?
ohm-ish
Post by ohm-ish »
I wonder..
Could a guitar bridge piezo work as a drum piezo too?
(for a DIY roland BT-1 or similar bar)
Wider sensing area. IF it could work as I dream it would :)
They can be bought cheap at ebay, so maybe it's worth trying out?
Other variation:
ohm-ish
Re: Guitar piezo as drum trigger?
Post by ohm-ish »
So.. I couldn't wait and just ordered one in the second picture, dirt cheap on ebay.
Must try it out, and at least get some knowledge about it. Learning by doing.
But still interested in tips or info if you have some
Not sure how you'll fit a bridge one. I've got a £4 ukulele one that works well on my cymbals
evh0u812
Post by evh0u812 »
Yes they work
