I'm in the process of converting some LV cymbals and wish to build a 'proper' high hat.
I had thought to use my current Goedrum GHC high hat controller, and augment it with this 3D printed component from Project Beats to allow space for the lower cymbal:
https://payhip.com/b/dDfw
But, with the eDRUMin 'impact' option, is there another way using just a piezo on the bottom cymbal or something like that? Forgive my ignorance, I have no idea now the VH13 type hat actually works!
Thanks.
DIY (metal) High Hat options
Re: DIY (metal) High Hat options
Using the impact method, you don't need a second piezo, if that's what you are asking.
How does it work? Is this a DIYable method? Just exploring optionsRob wrote:Using the impact method, you don't need a second piezo, if that's what you are asking.
