hall sensor for hihat input wiring diagram.
marviz
Post by marviz »
I have a Edrumin and tomorrow i will get my analog hall sensor to use with pedal input.
Can you provide wiring scheme how to connect the pins to TRS and how to set up in eDrumin?
I will get this one: https://sensing.honeywell.com/index.php?ci_id=50341
part number: SS49
Re: hall sensor for hihat input wiring diagram.
As long as the sleeve is ground, it shouldn't matter. The pedal input has auto polarity reversing tech built in to support both Yamaha and Roland style wiring.
marviz
Post by marviz »
Thanks, i will post my DIY tomorrow.
marviz
Post by marviz »
Well, it's not that the polarity does not matter, actually if you switch Ring and tip it does not work. So, here is a diagram that i made that works 100%
TRS jack:
Ground goes to hall sensor Ground (or 0)
Ring goes to hall sensor voltage input (or +)
Tip goes to hall sensor data/analog signal (or signal)
Rob - It would be nice if this could be in manual on wiring page.
There is one slight disadvantage to putting the sensor on the foot pedal. It keeps you from using a quick release hi-hat drop clutch.
If the sensor is on the pedal you won’t be able to do double bass work while staying on a closed hi-hat. I suspect this isn’t an issue for most people though as they may not care.
If you put the hall sensor up in the cymbals the disadvantage goes away.
marviz
Post by marviz »
My DIY Hihat controller. And yea, you can use it on cymbal with drop. Not my level of drumming tho...
I like that design, no drilling or fabricating required.
I would add a note on the diagram that you are looking at the sensor with the beveled edges up so right leg is tip, center is ground and left leg is sleeve will help
marviz
Post by marviz »
Well, i could but... If someone can't see the bevel on the image, that would mean that he shouldn't do it by himself ;)
marviz wrote:My DIY Hihat controller. And yea, you can use it on cymbal with drop. Not my level of drumming tho...
I also made the assumption a traditional two cymbal hi-hat set is being used. I forget there are a lot of signal cymbal hi-hat setups out there.
Hi! Interesting thread. I have tested an FSR sensor but those are not linear. At least that one i have.
I will try the Honeywell Hall sensor.
Is it working well?
Rob, what is the smallest delta of the voltage when using your HiHat Controller input. This Honeywell at 5V input goes from approx 1,0 to 2,9V. Should be enough, because you calibrating the input so that 1,0 V is 0 and 2,8 is 1024.
Am I right, saying that a linear response is better than logarithmic. I think the most pedals have a linear dependence between pedal and cymbal movement. :)
