Anyone using Goedrum membranes for LV cymbals with edrumin success?
I use Mryk membranes tor 18” ride snd hats. But being out of stock, goedrum is the only alternative plus they do 20” membranes.
Goedrum membranes?
Re: Goedrum membranes?
I can't see why there would be any major difference between different membrane switches. It's just an on/off switch.
yeah Rob, that's what i was thinking. thankx for heads up
I use them on all mine. Well except one still has myrks on it. I have the goedrum membrane just haven't gotten around to switching it out. I find them far superior. Twice as much coverage. More sensitive. And easier to wire. Although they are significantly more pricey.
Hey chris thankx for the update.AKA Wayne wrote: ↑Mon Mar 18, 2024 4:24 amI use them on all mine. Well except one still has myrks on it. I have the goedrum membrane just haven't gotten around to switching it out. I find them far superior. Twice as much coverage. More sensitive. And easier to wire. Although they are significantly more pricey.
Did you use the bell piezo or the membrane for the Ride? I can't remember from our conversation months ago. also did you run into any issues at all with dampening other than using the rubber rim edging?
ordered my eDrumin10
thankx
ron
I use a bell piezo with great separation via edrummin settings.
