correct AWG for piezo's
Gerwald van der Bij
Post by Gerwald van der Bij »
Hello,
Does anyone know what the best AWG is for extending the the wires that are on the piezo?
My piezo's all have different gauges but I am looking for the best way to go.
Re: correct AWG for piezo's
It's not going to make much difference because all the inputs have opamp buffered. Just use what you got, and solder well.
