Position sensing
bbuster90
Position sensing
Post by bbuster90 »
I want to do my own acoustic to electric drum conversion and would like to know what i need for position sensing?
Will any piezo mounted in the center work?
And what is the benefit (or not) from 3 edge mounts with or without center piezo?
Re: Position sensing
All the suggestions in the following thread about hotspot suppression apply equally for positional sensing..
viewtopic.php?f=34&t=951
bbuster90
Post by bbuster90 »
Thank you for your quick reply, so if i am correct, all piezo's "could" work (also the amazon's for example) but how good it works depends on the items listed in the topic?
And 3 edge mounted piezo's and 1 center piezo can also work? Does this have benefits or is it not worth the troubles?
I am new to this but don't want to build something that could be simply improved by adding a few more things for example
The ED10 should be in stock in May again, is this still accurate?
Positional sensing on 3 side trigger pads is experimental at this point. I would stick with a single center mounted sensor.
It's looking like late May to early June.
bbuster90
Post by bbuster90 »
Thank you, going for the single center mount than.
Ah, wished it was available sooner but thank you for the update
bbuster90
Post by bbuster90 »
Is it just this chip that you need to find for completing the modules (what you said in another post): MK66FX1M0VLQ18
I see here they should have 240 in stock
https://www.ztztechnology.com/component ... scale.html
Here other webshops are listed too
https://octopart.com/mk66fx1m0vlq18-nxp ... s-70306457
