Pots?
ddropski
Pots?
Post by ddropski »
Hi everyone I have 9 pintech concert cast pads everywhere I see points to me having "Hot pads" so I wanted to get on top of this before I start setting up the set (Im using over 100$ in foam from pintech only to find out they will make my pad hot) so amazon potentiometers are super cheap .. I was looking to put potentiometers in my pads but I'm not sure which value or type to use .. I would be very grateful if someone with experience can tell me the right types and value 10K or 100K
I already have the holes for head and rim already drilled .. thank you
