How do i what revision my edrumin4 modules are?
Optical hi hat
Re: Optical hi hat
What are v4's and v5's? I had to invert and use Yamaha wiring. I have power to tip and ring to a0. Are you getting movement? What does your calibration range look like? I did it easier to work in levels mode. You are in cc mode.
Re: Optical hi hat
If you go to the firmware section of the control application, you'll see the hardware revision in the top right hand corner.
If you device is plastic, you'll see ED4 or ED4R2. The metal ones are ED4R3 or ED4R4.
Re: Optical hi hat
Hey chris,
No problems with that inversion. But today i reversed connections to be: vcc -> ring and A0 -> tip. Now its Roland wiring. No issues.
Re: Optical hi hat
Nice. Mine is working so good right now just getting juice from the edrumin. I'll probably wire my extra box the Roland way since everything I have is wired the Roland way. Gotta keep things consistent ya know.
