Out of stock
Out of stock
Update: eDRUMin 10 is back in stock.
eDRUMin 4 and eDRUMin 10 are currently out of stock. I should have more eDRUMin 10 unit available by early next week, around December 6th. eDRUMin 4 internals are being upgraded and should be available in January or February next year.
Re: Out of stock
Glad to hear business is booming. Well deserved.
Re: Out of stock
Absolutely!
Great job, Rob!
Re: Out of stock
If anyone in the US needs an E10 my friend Alex is selling one he just bought a few weeks ago. I bought some other stuff from him - he's a fast shipper :D. Please let me know if you need his info.
Re: Out of stock
That's really cool.
And it's really strange that other companies still using a tiny display on their quite expansive modules.
And their users need are able to set thousands of voices.... hmm!
nwyard
Re: Out of stock
Post by nwyard »
Hello! Is there a way to receive email notification when the eDRUMin 4 stock is available? I am registered. Thank you.
Re: Out of stock
I'll reply.to this thread when it's back in stock.
nwyard
Re: Out of stock
Post by nwyard »
Rob wrote:I'll reply.to this thread when it's back in stock.
:D Cheers!
orand
Re: Out of stock
Post by orand »
Rob wrote:eDRUMin 4 internals are being upgraded and should be available in January or February next year.
Does the ED4 upgrade bring it up to parity with the ED10 in terms of processing speed and handling a wider range of gain?
Re: Out of stock
It will have same input circuitry as ED10, so yes will handle a wider input range just like ED10. Also, the pedal input circuitry is being upgraded and will be able to maintain a higher voltage in high current draw situations, which means it'll be able to power 3.3v hall effect sensors and photo resistors without using external power.
