eDRUMin version 1.3.2 BETA
eDRUMin version 1.3.2 BETA is ready for testing. I will maintain updated links to the latest BETA version below. You can downgrade from this version without loosing your settings. As always, your feedback is much appreciated.
PC
https://www.audiofront.net/eDRUMin_Cont ... 3.2.19.zip
macOS
Bug Fixes and Changes since 1.3.1
  • Fixed a display issue when plugging in multiple devices after the UI is already open.
  • Fixed an issue where pressing the hihat down very hard wouldn't apply the correct about of hihat crosstalk cancelation.
  • Fixed the splash sensitivity meter for impact mode.
  • Fixed dual mono input with metal cymbals.
  • ED10 pedal sensing adjustment to prevent a FSR from being incorrectly detected as an expression pedal.
  • Updated factory presets.
  • Included presets made by monospace in the set of factory presets.
Changes in build 19
  • UI Performance improvements.
  • Fixed an issue that could cause dropped data packets coming for devices connected to the USB host port on ED10.
Changes in build 11
  • Fixed note controls not properly updating when entering in a value using the keyboard (since build 7).
Changes in build 10
  • Fixed crash when when changing pad type of input 10.
Changes in build 9
  • Allow updating firmware of devices connected to the ED10 USB Host port.
Changes in build 8
  • Bug fixes.
Changes in build 7
  • Updated graphics library.
  • Fixed UI performance issues on macOS.
  • Fixed a hihat CC issue related to using expression curve.
  • Fixed a crash when unlinking and then relinking hihat.
  • MIDI Channel now properly follows setting in note banks.
Changes in build 2
  • Fixed an issue with some hall effect sensor based hihat controllers.
  • Fixed polarity control for hihat controllers.
Changes in build 1
  • Hihat engine improvements.
monospace gets a mention in the update notes
well deserved
That’s really flattering but bear in mind that what works for me may not work in someone else’s setup without additional tweaking. I try to get the best response out of an individual trigger but I also make adjustments to make them sit well with the rest of my pads. They’re starting points, at most. Your mileage will vary.
Molson
Post by Molson »
I'm trying to update from 1.3.1.15 to 1.3.2 but it only keeps flashing "Waiting". I've tried re-booting the computer (Mac), and re-plugging the ED10 but nothing seems to work. Any ideas?
I tried on my development machine, running Mohave, and there were no issues. What version of macOS are you running?
Molson
Post by Molson »
Mohave as well. I finally got it to work. I had to delete the eDRUMin app from applications and re-install 1.3.2. Once I did that it let me upgrade the firmware. Really odd though - I've never had that happen on prior builds.
Super minor thing I've been meaning to mention for ages: the End User License Agreement on the eDRUMin installer is for Midi Expression.
Not that I've ever read it...!
I installed it and made no adjustments after. Just worked through a 30 song practice list and everything worked great as usual.
Changes in build 1
This build should give your hihat pedal more definition and responsiveness.
Rob wrote:Changes in build 1
I noticed it played better. Was more responsive - tracks my foot movement better
