Which pre-set to use? Roland TD11 or SD3
Macdanger
Post by Macdanger »
Hi All,
I have recently received the eDRUMin10 and will be starting to set it up later today. I have a question about the pre-sets.
I have a Jobeky kit with Roland hi-hat and cymbals, and was using a TD11 module to trigger SD3.
As it's a mixed kit of Roland cymbals and acoustic trigger drums, which pre-set should I initially use on the eDRUMin before tweaking? Should I use the SD3 pre-set or the Roland TD11 pre-set. When I was using the TD11 it was triggering things correctly in SD3 but didn't have positional sensing on the snare which is why I ordered the eDRUMin.
If I set it to SD3 how would the eDRUMin know that I have the VH11, 2 x CY-12C and the CY-13R?
Thanks for the advice.
Stuart
anton
Re: Which pre-set to use? Roland TD11 or SD3
Post by anton »
Do you plan to use both? eDRUMin and TD11 or just the eDRUMin?
You can set the mapping in the eDRUMin control application, page 21 in the manual.
Anton, brings up a good point. If you are still using the TD-11, then it might be easiest to use the Roland map in eDRUMin and SD3. If you aren't going to be using the TD-11, then I would use the SD3 preset in SD3 and eDRUMin because the SD3 map is more extensive and covers more kit pieces.
Macdanger
Post by Macdanger »
Hi guys,
My plan is to sell the TD11 and only use the eDRUMin as I don't intend gigging the kit, so will not require on board sounds.
Based on what you've said I'll set the pre-set to SD3 on both the SD3 and eDRUMin. If I do that on the eDRUMin do I still have the opportunity to tell the eDRUMin which HH and cymbals I'm using to ensure I get the best triggering?
Thanks
I used the SD3 Map in the eDRUMin control program but create a separate user midi map for each SDX. Actually the only the cymbals change so I use a base SD3 map and then edit that one and save it as separate ones for each SDX.
