I just bought an eDRUMin 10 and now I need cables since my module use a cable snake and I won't be using it anymore.
Is there any recommendations for quality, length, type, price... that would be useful?
It would be a standard kit 5 Piece and diy LV Cymbals (2 crashes, 1 3zone ride) so I was thinking all stereo cables but that's about the information I know for cables.
Cables
Re: Cables
I make my own so that I can have them just the right length. I think pretty much any stereo cable you find will work fine, though.
Re: Cables
I got a bunch of 3" and 5" Hosa TRS cables off of Amazon. Cheap and reliable. Make sure to get them right angled on one end! My ED10 is mounted smack in the middle of the rack (never understood why modules are mounted way left) and everything is reachable. Get a bunch of velcro cable ties to tidy everything up.
