Here is my set up, using 1 edrumin:
Input 1: Kick mesh head with RT30K trigger + Snare mesh head with Tdrum side trigger. I use this splitter: https://www.thomann.de/intl/pro_snake_tpy_2003_jbb.htm
Input 2: HiHat Roland VH-10, with the control output to the back of the edrumin. I made the 2 stereo cables cause they were not sold with the VH-10
Input 3: Dual MONO input: Millenium stereo crash 14" + Floor tom mesh head side piezo. With the same splitter as input 1.
Input 4: Yamaha PCY155 ride.
The edrumin firmware is the newest avaiable.
I reassign manually all notes to match the notes in the software Abbey Road drummer (Native Instrument, Kontakt 5). A bit laborious, a preset would be appreciated
In stand alone mode, cause via Cubase is it unplayable due to the latency
Issues:
- Input 3: the stereo crash doesn't arrive in the edrumin software. I suspect the splitter, how can I modify this splitter?
- Input 2: the hihat control and trigger works really poorly with Abbey Road drummer. Is it normal?
What am I doing wrong? Does anybody found the way to use kontakt drums in a great playable way using triggers/cymbals and edrumin?
I've spend lots of time to try several settings, and it is far from conclusive at the moment.
Thanks in advance for every idea to improve my set up !
HiHat: https://www.dropbox.com/s/8bnyx1rqaig5ftc/hh.png?dl=0
Pedal control: https://www.dropbox.com/s/xxcapujjdr10k ... l.png?dl=0
Crash: https://www.dropbox.com/s/mtjfhokbyhg4w ... h.png?dl=0
Floor tom: https://www.dropbox.com/s/gji7gyo6j1sso ... r.png?dl=0
A to E drums: https://www.dropbox.com/s/f4tapamnp4l3s ... s.jpg?dl=0
