Rob - Just got my eDRUMin and am getting ready to start tinkering around with my ATV snare and ATV hihats... Thanks again by the way! Before I get into it, do you have any advice on settings for an ATV 13" snare? The trigger setup is 3 head piezos / 4 rim piezos all wired parallel (from the general consensus over on the vdrums forum), and given that there are 3 head piezos which are all "side" mount, would I just simply select mesh side piezo for the pad setup? Or would you recommend I stick with mesh center piezo?...
Anyone out there running ATV pads on an eDRUMin yet???
ATV Snare
Re: ATV Snare
How has the experience been with the atv pad and edrumin?
Re: ATV Snare
So I set up the eDRUMin with the ATV snare with the pad configured to Mesh Side Piezo. Ended up needing to bump the gain .2 to get it where I wanted and set the velocity curve to be a little more punchy. It seems to have tamed most of the hotspotting I was seeing from the ATV pad on my TD-50 out of the gates, but I still need to play with hotspot suppression to see if I can dial it out completely.
So for the snare - I’d definitely say it’s doing exactly what I’d hoped it would... Even though it doesn’t officially have a multi-piezo pad setting.
The ATV 14” hihats are next up on my list to tackle after I finish tuning the snare. Probably a separate thread though.
Re: ATV Snare
Can you please follow up with how things went with your atv set-up,I have a ATV-EXS 5 full size kit & I need to get edrummins but don't know how many I need nor what splitters nor if atv even works with edrummin? Your input ANY inputs greatly appreciated.rdubu wrote:So I set up the eDRUMin with the ATV snare with the pad configured to Mesh Side Piezo. Ended up needing to bump the gain .2 to get it where I wanted and set the velocity curve to be a little more punchy. It seems to have tamed most of the hotspotting I was seeing from the ATV pad on my TD-50 out of the gates, but I still need to play with hotspot suppression to see if I can dial it out completely.
Re: ATV Snare
2 edrumins. Dual zone everywhere, 3 zones in the Ride.
2 Splitters cables , for the 3 Toms and the kick.
ATV stuff works amazing.
