Inputs doesn't work in dual mono mode
arkserg
Post by arkserg »
HI, Rob!
Just tryed to connect all my drums to eDrumIn and found a bug: dual mono input only works when selected in the ui. As soon as you select another channel, second pad of splitted input stops sending midi notes. Same if you close the control application.
Hope it is just a software bug that can be simply fixed.
Thank you.
Re: Inputs doesn't work in dual mono mode
News to me. I use dual mono all the time and haven't noticed any issues. For the input that you set to Dual Mono, what are the two pad types you are using.
arkserg
Post by arkserg »
Mesh side piezo for both pads.
Just check it again: same result on any input, as soon as I select another input or close the control application second pad stops sending notes.
Confirmed bug. I've fixed it already and I'll include it in the next update. For a workaround, change the tip pad type to 'Rubber Pad'.
arkserg
Post by arkserg »
Ok, thank you!
Fixed in version 1.0.3.1.
