Advanced mode in future app update
Pim
Re: Advanced mode in future app update
Post by Pim »
marviz wrote:Hi,
Im about to get eDrumin in couple of days now. But im wondering...
There is 4 stereo inputs so basicly it can handle 8 single piezos. As for now i can see in manual that this is no way can be separeted using cable splitter and get true 8 separeted pads to configure.
Can you implement an advanced mode so every input would be on seperate tab? I dont need rim shots on toms or cymbals in some cases. It wiould be nice we could have that advanced mode to work on. Even kick pad is single piezo, we do need option to seperate TRS to 2 tabs in app.
When you use the Dual Mono mode, you can switch back and forth between the settings of each mono pad.
Best regards,
Pim
