Cable Splitter
Cable Splitter
Is there anything special I need to consider for a cable splitter for the eDRUMin?
Will this one work? https://www.guitarcenter.com/Hosa/YPP-1 ... e&index=21
Mister Dudicle
Re: Cable Splitter
Post by Mister Dudicle »
That cable is going to replicate Tip and Ring from the TRS plug to each of the 2 jacks.
If you want to *separate* the 2 zones such that zone1 goes to Tip on one cable and zone2 goes to Tip on a second cable,
then I think you need a TRS-to-TS "breakout" cable, something like this:
https://www.sweetwater.com/store/detail ... tsf-6-inch
Re: Cable Splitter
I have a Field 18” 3-zone ride that is setup the following way:
Output 1 is setup as a Dual Zone cymbal (piezo / switch) and handles the bow / edge. Output 2 is setup as a Mono Input and serves to trigger the bell.
Since Output 2 is essentially a 1-zone trigger I should be able to split that eDRUMin jack with the 1-zone China I have. Is this a correct assumption?
I figured if I stayed all stereo eDRUMin would figure it out. :D
Mister Dudicle
Re: Cable Splitter
I can't speak for eDRUMin capabilities, but it seems to me that the adapter I posted is what you want.
Or be safe and order both ;-)
Re: Cable Splitter
Mr Dudicle ist right. You need to separate the tip and ring. Actually there are some eDrum Modules, like Roland, that need a resistor between
certain points. I dont know that for the eDrumIn.
For my Alesis/FAME-like module it does quite well without those electrical components.
Bye
Re: Cable Splitter
Thanks for the input. I’ll try the TRS => dual TS. That sounds very logical to me.
I guess what worries me Is the jack on the cymbal is a stereo jack wired to the ring and if I put a tip only cable in there the signal won’t get through.
Pim
Re: Cable Splitter
Post by Pim »
Mylo wrote:I have a Field 18” 3-zone ride that is setup the following way:
Have you tried a standard mono cable with Output 2 (not with the eDrumin, but with your old module)? If this works, a standard Stereo-Y-Cable (e.g. https://m.thomann.de/gb/cordial_cfy_09_ ... 1578604412) will let you use both your bell zone and the China cymbal with the eDrumin.
Best regards,
Pim
Pim
Re: Cable Splitter
Post by Pim »
Ups again.
Re: Cable Splitter
Pim wrote: Hi,
Best regards,
Pim
I haven’t tried anything yet. My MegaDrum had plenty of inputs so this has never come up. The cable you are suggesting would be the equivalent to what Mister Dudicle suggested. So that’s what? Three or four votes for the stereo to dual mono. I’ll run with that and give it a try.
Re: Cable Splitter
Thanks everyone for the input. This is what Musicians Friend had so I grabbed it.
https://www.musiciansfriend.com/accesso ... 4f-y-cable
