Hihat control on Strike Module
slothamer
Post by slothamer »
Would this allow me more adjustment between the open and closed hihats on a Strike Pro module? Does it store the settings internally or would it have to be connected to a computer?
I use a Roland VH11 hihat on the Strike but cant get the sweet spot of partially open to register currently.
Thanks
Re: Hihat control on Strike Module
The settings are stored on the module, so once it's setup to your liking, you can just power it via a Roland style 9V brick. I don't have a Strike Pro module to compare with, but I have no issues getting a full range of hihat positions with my VH-10. If you want to buy one and test it, you can always return it for a full refund if you're not satisfied.
