Which mapping inside SD3?
CodaClef
Post by CodaClef »
Which mapping/preset should I chose INSIDE SD3?
I am using the SD3 preset in the eD, but not sure what to chose in the MIDI in/edrums settings in SD3...
So many choices, too bad Toontrack hasn't added the eD yet...
Thanks!
Re: Which mapping inside SD3?
I'm using a DIY 5 piece A2E kit. I settled on using the Roland mapping in the eDRUMin and SD3.
