My Surge is classicaly composed of :
1x HH
1x Snare
1x Tom High
1x Tom Low
1x Floor tom
1x Kick
2x Cymbals
- I want to upgrade to a better hihat, and set my mind on a Drum-tec Zeitgeist ZG-H12
Hi-hat : https://www.drum-tec.fr/zeitgeist-zg-h- ... ece-hi-hat - Also planning to do an A2E of a snare with a Jobeky Trigger
Snare Trigger : https://jobekydrums.co.uk/product-categ ... /a-i-v-20/ - Optional, get a "big" two or three zone ride
Does the Hihat and snare trigger arre compatible ?
If I understand it correctly, and according to the documentation, I could get an edrumin 4 and use the usb host to connect the Alesis Surge module to it for the rest of the cymbals and pads.
So I think a 4 entry eDRUMin would be enough for the 3 options :
1 TRS for HH Pedal (dedicated port)
1 TRS for HH Cymbal
1 TRS for snare
1 or 2 for the Ride Cymbal
Am I right ?
But If I want to get rid of the Alesis module altogether, an 8 would be the bare minimum (with splitters)
Thx for your help.
