Dear friends,
I just ordered an edrumin 8, very excited!
I was wondering if anyone around here has any experiences with using the edrumin with the Millenium MPS1000 pads, especially the snare.
I can get a set for a really good price, so I was wondering if that would work.
Hope to hear from you!
Cheers,
Michiel.
eDRUMin newbie question
Re: eDRUMin newbie question
I don't see why not.
Online, they say they have two separate trigger zones. That doesn't say if they are piezo-piezo, or piezo-switch.
Once you find out, you will need to select the appropriate preset from the menu.
On another note, I didn't know Millennium was offering real shell looking kits.
