Strata prime compability
Hi. Just wondering if anyone has has the chance to try espcially the arc cymbals with an edrumin module.
Re: Strata prime compability
I’m interested in this as well. I know the Arc cymbals only use 1 cable. Does it work like the Yamaha cymbals?
Alesis usually follows Yamaha's style wiring, so yes, it would work just as well. Just select the right preset.
There's no new technology under the hood. Still the same old piezos et resistors. So, you'd be good using them with the eDRUMin.
