Avlinux basic problem with edrumin not running [Solved by updating both ]
MpD0
Post by MpD0 »
Anyone got edrumin working with avlinux? In particular the new 23.1
I am not able to open edrumin after installing.
Thank you
M
Re: Avlinux basic problem with edrumin not running
What hardware are you running?
MpD0
Post by MpD0 »
I have everything working in Windows 10 and also Linux mint ( minus some lack of understanding of Ardour and reaper.)
Basically Yamaha cymbals and silicon pads. 2 x edrumin 4 into intel 12600 based PC via usb then out to Behringer 404 interface.
After the install proceedure I get an icon in the Avilinux applications section but when trying to run get
Enlightenment was unable to run the application
/opt/edrumin/edrumin
The application failed to start
Enlightenment is the Avlinux desktop environment.
I have posted on linuxmusicians forum where avlinux developer participates.
M
MpD0
Post by MpD0 »
Had another try. Updated Avlinux and unistalled eDrumin and then installed the newest beta.
eDRumin now running.
Thank you.
(Still trying to work out how to get eDRumin working with Ardour etc )
M
