Kick Mistrigger with Cymbal Hits
Mat1515
Post by Mat1515 »
This one may be hard to diagnose, but not sure where to start.
I've recently developed an issue with lemon 2 zone cymbals where when I strike the switch portion of the cymbal...for some reason it is canceling out the midi signal assigned to the kick drum. So weird.
Any ideas?
I've checked the midi feed out to EZdrummer 3 and it appears to be an issue within Edrum10. Running 2.3.1.16 version
Re: Kick Mistrigger with Cymbal Hits
What do you mean by "cancel the midi", do you mean playing kick and lemon crash only the crash sounds? in that case check your crosstalk settings for kick and crash.
Mat1515
Post by Mat1515 »
cross-talk did help, the manual is still confusing me...
is the cross-talk meter on a channel displaying how much cross talk is coming into that channel from other drums? And the number should ideally be higher than the max amount of cross-talk coming in? Or is it more reasonable to have a bit of bleed?
Greetings from Columbia. There's a good clear write up in the manual about cross talk cancellation.
