Just wondering if there's any chance on a future update to the edrumin software to have the ability to add text or change the icon of a pad input aside from the current ones such as a cowbell icon, jamblock etc... When I look at the software, I can't always remember whats plugged in to what input unless I hit the pad. Maybe theres already a work around for this? Cheers
Brad
Ability for text or different input icons
- Screen Shot 2023-12-20 at 4.49.20 PM.png (99.04 KiB) Viewed 3143 times
Re: Ability for text or different input icons
No chance of getting text, but if you switch over to using a drum maps and kit peices, you get more informative icons.
