Yamaha RH1135 Hihatt only getting close and open 6
Bassforlife2008
Post by Bassforlife2008 »
Hey guys,
I know the pad itself has a preset and that seems to work well. Was wondering if anyone has any inight on how to get the foot controller portion to work better. Right now I am using the HH65 foot pedal preset and did the calibrate but I really cant achieve anything other then close and open 6 position if i try.
Re: Yamaha RH1135 Hihatt only getting close and open 6
Have you set the polarity to Yamaha? After you set it to Yamaha, you'll need to recalibrate.
