Im planning to invest on eDrumin hardware for my eKit set which need 15 inputs at this moment, i already had ED8 (surely not enough)...
considering go with ED10+ED8... or just use double ED8?
if allowed it would b nice to hav everybody shares n experiences bout pros n cons of it plz (since i absolutely blind in case connecting them all... just known it can be paralelled 4 units simultaneously) , thanks in advance mates
eDrumin Best Configurations
Re: eDrumin Best Configurations
I'm not sure but there could be differences between the 8 and the 10 aside from these two:TOP wrote: ↑Tue Nov 07, 2023 2:21 amIm planning to invest on eDrumin hardware for my eKit set which need 15 inputs at this moment, i already had ED8 (surely not enough)...
1) Two more inputs
2 Two PED inputs for the 10
Hi Mr. E... thanks for replying...
im pretty sure there's something else coz ED10 seem got On/Off button on it.
Yes, ED10 has on/off button and can be powered by a 9v power adapter.
Hi Rob... thanks for joining in...
in what condition adapter is necessary? and how to connect it with ED8?
ED8 does not have a DC power input. The specs for the power adapter are shown on the device itself and in the getting started section of the manual.
DC Power Connector
The other thing to consider is availability.
Per the Audiofront product listing here:
https://www.audiofront.net/eDRUMin.php
The eDRUMin 8 will be available in Dec, but the eDRUMin 10 won't be available until March.
Thanks Rob... read again manual...just redownloaded it again (Lol) ... i got all of my anwered bout ED8 Information... just 1 question left behind that is: if i connect RD8 with ED10... i better use usb host port between them instead of midi pin for ensuring enough power right?
Thanks for ur enlighment
Yep.. i noticed it Mr.E, thanks 4 reminderMisterE wrote: ↑Tue Nov 07, 2023 4:40 amThe other thing to consider is availability.
I realized It really takes patience to grow developing this product.. but somehow i hav faith that its worthed
Both ED10 and ED8 have USB host ports, and that's the easiest way to go because you don't need to use an MIDI cables and everything will run on USB bus power. Check the manual for more information.TOP wrote: ↑Tue Nov 07, 2023 4:42 amThanks Rob... read again manual...just redownloaded it again (Lol) ... i got all of my anwered bout ED8 Information... just 1 question left behind that is: if i connect RD8 with ED10... i better use usb host port between them instead of midi pin for ensuring enough power right?
eDRUMin USB Host Power
