using ED with lemon T950
TOP
Post by TOP »
hi all...
im totally newbie here.. and still waiting for my EDI8 arrive
im planning to use it with lemon T950 drumkit to trigger Superior drummer 3
would u guys kind enough to give some of ur experiences to enlight me how to do it plz? :roll: so i can have "Roland VAD706 wanna be" experience (if i may say so)
Pardon my English... as its not my native... and im count on google translator for it
thanks in advance
Re: using ED with lemon T950
just plug the pads into the ED8, then watch a few videos about setting up SD3 with your computer.
It's not too hard.
Good luck!
TOP
Post by TOP »
Thanks 4 ur respon, i was thinking bout plug certain pads of T950 into EDI8 (maybe snare and ride to get them positional sensing for a start) .. and keep others in lemon module, then connect both modules to trigger SD3.
has anyone had any success for getting a positional sensing to lemon's snare. an ride? Are there a certain ways and tricks that I should know to do it?
Thanks again
For the snare, the piezo needs to be in the center.
If it is one the side, you will net get positional sensing.
TOP
Post by TOP »
till now I've managed to connect a dtx720 to control the SD3 btw, but yeah it has no positional sensing at all... so it's not realistic n machine gun effect all over the place
Yamaha does not support positional sensing with the DXT700.
And yes, it's a very old module, and nothing like SD3.
When you listen to DTX700 only, it's not great, but when you play with a band, it's not too bad.
TOP
Post by TOP »
thanks perceval.... it very kind of u helped me with my questions.... i bet u hav a lot of experiences setting up edrumin with an electric drum before?
I had a DTX700 before, then added eDRUMin so I can use DIY drums.
And really liked the unit.
TOP
Post by TOP »
what kind of DIY? Does include part of lemon drum too?
TOP
Post by TOP »
can i get bell zone from lemon 13 inch dual zone cymbal with bell sense?
has anyone ever try it?
Thanks in advance
