Can I control two hi hat pads from one hi hat controller?
Rabidreject
Post by Rabidreject »
Pretty much all in the question, if not I guess I’ll get an x hat and just set it to what I want.
I’d be surprised if you couldn’t do what I’m suggesting though…
Re: Can I control two hi hat pads from one hi hat controller?
Yes, you can. You can have as many hihat pads as you want. You just need to set the pad function of those pads to 'Hihat 1', assuming your hihat controller is plugged into the first pedal input.
Rabidreject
Awesome, thats gonna really give my arms a rest! Thanks
