Edrumin10 Revision1 and Revision2?
stipsi
Post by stipsi »
Hello,
is it true that there are different hardware versions of edrumin10, Revision1 and Revision2? Where's the difference?
How can I recognize that, is it written somewhere?
LG Christian
Re: Edrumin10 Revision1 and Revision2?
Revision 2 has an improved pedal input which provides slightly better hihat pedal resolution and more power for Hall effect sensors.
stipsi
Post by stipsi »
Ok, thanks!
Darthvim
Post by Darthvim »
Is there a way to mod the v1 version to v2?
If so, could you provide any instructions?
Can't be done.
