Multiple edrumin 4’s
Digs0607
Post by Digs0607 »
Hi
I can see that it is possible to connect multiple edrumin 4 units via a usb hub.
Does anyone know if this possible to connect multiple edrumin 4 units to one drum module?
Thanks in advance
Re: Multiple edrumin 4’s
Digs0607
Post by Digs0607 »
Is it possible to use multiple edrumin 4’s not connected to computer?
Probably not easily. You would likely need to merge the MIDI together and route it to your module. Much easier with an ED10. Rogjt now it's looking like I'll have them in stock in May, but that's a rough guess and when they do become available, they likely won't last long.
Digs0607 wrote:
Thu Dec 15, 2022 10:32 pm
Ah apologies, misread
